SuzieSmith
Feb 08, 2017Aspirant
Firmware upgrade possible ?
The model is : Netgear N300 wireless ADSL2+ modem router DGN2200v4 I am currently running firmware version V1.0.0.24_5.0.8 The 'firmware upgrade assistant ' says ..... a 'router firmware u...
- Feb 09, 2017
SORTED ......
thank you you very much Michaelkenward ..
the zip/unzip app has opened the file in iCloud through airdrop
many many thanks you you guys are wonderful ......did you all know that ???
Gee ...it's great ...I shall now proceed with the firmware upgrade
thank you thank you 😃😃😃😃😃
SuzieSmith
Thanks Netwrks Master .....been there .....no good .🙁
as I am only on an iPad Air I'm thinking I'm limited and it isn't allowing me to open the download in Safari , Viber , Firefox or email to myself . I did get as far as 'browse' in one of them but then it wanted a ....*cx file ...... or something so then I was lost !
any other suggestions ?
VE6CGX
Feb 08, 2017Master
When try to scroll down the update page, what happens? Are you clicking the right arrow?
- SuzieSmithFeb 08, 2017Aspirant
No right arrow here .... if this is the routerlogin.net website you are talking about where I can't scroll down on the 'router upgrade assistant ' page . The bottom of this page seems to be behind a HELP and SUPPORT panel along the bottom of the screen ...... and the screen does not want to allow me to scroll up to get to the bottom of the page on upgrading my firmware .
like the page is frozen on the screen , won't go up or down .
kylie
