Viltro's avatar
Viltro
Firmware "upgrade"
My model is actually a R6900 but that doesn't show up in the selection to make this post. I made the mistake of "Upgrading" the firmware to V1.0.1.34 yesterday.  I should have left it at the old vers...
  • antinode's avatar
    Jan 23, 2018
    > How can I downgrade the firmware to a version that works????
       Leaving aside the question of whether any version actually "works",
    visit http://netgear.com/support , put in your model number, and look
    for Downloads.  Under Firmware and Software Downloads, look for View
    Previous Versions.  Download the kit you want.  Read the "Release Notes"
    file for instructions.
