dbakyle
Feb 07, 2017Aspirant
Firmware V1.0.1.20_1.0.16 and Gene Access Stopped Working
This morning I upgraded my router to the latest firmware, V1.0.1.20_1.0.16. This afternoon I tried to access the router page and it's no longer acting like it did. When I try to use the Genie appli...
- Feb 08, 2017
Yup. It is a pain. Screen grabs can help. (Alt+PrintScreen)
Here's how I go about it:
- save (backup) settings
- flash firmware
If that works and you see no problems, great. If not, and something doesn't work,you may have to reset the device to the default settings:
- set to factory settings
- retrieve settings from backup
If that works and you see no problems, problem fixed! If not:
- set to factory settings.
- reconfigure everything
If that fails, then I fear that you may have to flash back to earlier firmware.
michaelkenward
Feb 08, 2017Guru - Experienced User
Did you "factory reset" after the firmware update?
This isn't always needed but it is the first thing to try if you have post-flash issues.
Sometimes new firmware changes things that are not compatible with the older configuration.
dbakyle
Feb 08, 2017Aspirant
I didn't do the factory reset. While it's something I could try, it's not something I would look forward to since I've setup this router over the last year and it's working great, at least it was. Resetting means I have to remember all the configuration changes that I made and remake. Sounds like a weekend job to me.
- michaelkenwardFeb 08, 2017Guru - Experienced User
- flash firmware
