hartage
Jul 28, 2017Aspirant
firmware V1.0.1.24_1.0.18 update
my router r6400 just got a new firmware update V1.0.1.24_1.0.18 yesterday. Last night it's very first lockup that needed a hard reboot (power off/on) ever. Being the first lockup ever means a...
- Aug 03, 2017
Hi hartage,
We recommend doing a factory reset after updating the router's firmware. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
DexterJB
Aug 07, 2017NETGEAR Moderator
Hi hartage,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
- hartageAug 11, 2017Aspirant
Dexter, Sorry for the late reply, been busy. Yes the issue is still happening but it is now less often. Before it will freeze 1 maybe 2 times a day in seemingly random times usually at night. After doing a factory reset, first backedup settings then factory reset, then backup restore. After doing this the freezeup still happens but now once every couple of days. This is a vast improvement over 2 times a day to once every couple of days but still not the same as before the upgrade when it was stable 24/7 and never locked up.
- cescobarAug 11, 2017Aspirant
I encountered the following issues after upgrading to V1.0.1.24_1.0.18:
1. Slow WI-FI connection, to the point where at times it seemd to be crawling at a snail's pace.
2. VPN into my work's network slowed down considerably and this was over a wired connection.
3. Wired connections speed also slowed down significantly.
For now, I have downgraded to an earlier version of the firmware and this seems to have improved my connection. However, it is not as fast as it used to be before I upgraded to V1.0.1.24_1.0.18. I noticed that the GUI Language version is still set to V1.0.1.24_2.1.38.1, is there any way to downgrade the GUI Languare version as well?
