hartage
Jul 28, 2017Aspirant
firmware V1.0.1.24_1.0.18 update
my router r6400 just got a new firmware update V1.0.1.24_1.0.18 yesterday. Last night it's very first lockup that needed a hard reboot (power off/on) ever. Being the first lockup ever means a...
- Aug 03, 2017
Hi hartage,
We recommend doing a factory reset after updating the router's firmware. The link below may help out.
http://kb.netgear.com/app/answers/detail/a_id/9665
Dexter
Community Team
DexterJB
Aug 07, 2017NETGEAR Moderator
Hi hartage,
I would like to follow up and check if you are still experiencing the issue.
Dexter
Community Team
hartage
Aug 11, 2017Aspirant
Dexter, Sorry for the late reply, been busy. Yes the issue is still happening but it is now less often. Before it will freeze 1 maybe 2 times a day in seemingly random times usually at night. After doing a factory reset, first backedup settings then factory reset, then backup restore. After doing this the freezeup still happens but now once every couple of days. This is a vast improvement over 2 times a day to once every couple of days but still not the same as before the upgrade when it was stable 24/7 and never locked up.
- cescobarAug 11, 2017Aspirant
I encountered the following issues after upgrading to V1.0.1.24_1.0.18:
1. Slow WI-FI connection, to the point where at times it seemd to be crawling at a snail's pace.
2. VPN into my work's network slowed down considerably and this was over a wired connection.
3. Wired connections speed also slowed down significantly.
For now, I have downgraded to an earlier version of the firmware and this seems to have improved my connection. However, it is not as fast as it used to be before I upgraded to V1.0.1.24_1.0.18. I noticed that the GUI Language version is still set to V1.0.1.24_2.1.38.1, is there any way to downgrade the GUI Languare version as well?
- DexterJBAug 17, 2017NETGEAR Moderator
Hi cescobar,
Please make sure that you have done a factory reset after updating the router's firmware.
Dexter
Community Team
- DexterJBAug 21, 2017NETGEAR Moderator
Hi cescobar,
Thank you for the update. Please keep us posted if the issue will persist.
Dexter
Community Team
- cescobarAug 22, 2017Aspirant
Hi Dexter,
Sorry for the late response.
I did reset after I upgraded the first time, but it did not help. I even went back down to version R6400-V1.0.0.26_1.0.14 and upgraded up one version at a time from there every few days.
I have stopped using the router since last week because the slowness became too much to ignore. I decided to purchase a different one.
Thanks for the help.
