klim's avatar
klim
Firmware V1.0.1.26_1.0.19 disabled many of the advance settings
On the brink or reverting back to the previous Firmware.... V1.0.1.26_1.0.19 disabled many of the advance settings including the ones under Security. Access Control and Block Services are greyed out. I no longer have the ability to access those settings amongst other ones. Upgrading to V1.0.1.26_1.0.19 caused many settings to be greyed out especially the ones under Security and Advanced Setup.
Anyone experiencing the same issue?
  • klim's avatar
    klim
    Nov 09, 2017
    Yes I was able to resolve the issue. The router was placed in Bridge AP mode after upgrade. Thank you for the assistance.
  • DexterJB's avatar
    DexterJB
    NETGEAR Moderator
    Hi klim,
    Please make sure that the router is not in AP mode. You can check that under Advanced > Advanced Setup > Wireless AP. Also, please make sure that a factory reset is done after updating the router's firmware.
    Dexter
    Community Team
    • DexterJB's avatar
      DexterJB
      NETGEAR Moderator
      Hi klim,
      I would like to follow up and check if you are still experiencing the issue.
      Dexter
      Community Team
      • klim's avatar
        klim
