DMAANDAG
Mar 01, 2022Tutor
Firmware v1.1.0.1.108 login issues
After upgrading both my Netgear WiFi Extenders 6150v2 to the latest firmware (EX6150v2_EX6100v2-V1.0.1.108.img) , both extenders do not allow me to login. After pressing the login button I am immede...
- Mar 02, 2022
You have them hardwired in and running in access point mode?
the only notes I see on the release notes are "supports security enhancements"
Not sure exactly what that implies but it could be whats causing the issue.
You might be stuck with doing the reset/reinstall. could be one part of the security enhancement not working properly with the old settings.
Mar 01, 2022Guru - Experienced User
have you tried factory resetting and reinstalling them?
Sometimes firmware changes enough it causes issues.
DMAANDAG
Mar 02, 2022Tutor
To do a factory reset was the last option, but I was hoping not to have to do that.
If nothing else works and I can't get in, I might have to do that.
Thank you for replying.
