DMAANDAG's avatar
Mar 01, 2022
Firmware v1.1.0.1.108 login issues
After upgrading both my Netgear WiFi Extenders 6150v2 to the latest firmware (EX6150v2_EX6100v2-V1.0.1.108.img)  , both extenders do not allow me to login. After pressing the login button I am immede...
  • plemans's avatar
    Mar 02, 2022
    You have them hardwired in and running in access point mode?
    the only notes I see on the release notes are "supports security enhancements"
    Not sure exactly what that implies but it could be whats causing the issue.
    You might be stuck with doing the reset/reinstall. could be one part of the security enhancement not working properly with the old settings.
