wbarber520
May 04, 2018Aspirant
firmware v1.1.10.66 won't load up
Cannot install newest firmware v1.1.10.66. After downloading file, router crashes when trying to upload when using an eithernet connection.
- May 12, 2018
- Apparently Netgear fixed the bug in Firmware 1.1.0.66 1.0.1 and it now loads
- ok from Genie Firmware upgrade
wbarber520
May 05, 2018Aspirant
Trying to upgrade R6220 firmware v1.1.10.64 to v1.1.10.66 using the Genie upgrade feature (see screenshot) . Using wired eithernet conn the router downloads the upgrade ok and when it's upgrading the router, eventually it stalls and says the upgrade failed. Upgrade freezes the internet momentarily with only the power button on. After unplugging the eithernet cable, wi-fi resumes working as normal but did not upgrade to the latest firmware. Seems to be an issue in the upgrade software.
michaelkenward
May 05, 2018Guru - Experienced User
I hope I have interpreted that message correctly.
A first thought is that you might find it easier to read the release notes and follow the instructions there:
R6220 / R6230 Firmware Version 1.1.0.66 | Answer | NETGEAR Support
Download the firmware and then install it.
By the way, a good way to get screen grabs is to use Alt+Print Screen. That way you get rid of the surrounding clutter and home in on the topmost Window.
- wbarber520May 06, 2018Aspirant
Still won't upload. Appears something wrong with the file.
- antinodeMay 06, 2018Guru
> Still won't upload.
"won't" is not a useful description. It does not say what you did.
It does not say what happened when you did it. As usual, showing actual
actions with their actual results (error messages, LED indicators, ...)
can be more helpful than vague descriptions or interpretations.
Which "the file"? What, exactly, are you doing?
> [...] using the Genie upgrade feature [...]
If you're usng a Genie app, then I'd switch to a web browser. (Less
unreliable software that way.)- wbarber520May 12, 2018Aspirant
- michaelkenwardMay 07, 2018Guru - Experienced User
wbarber520 wrote:
Still won't upload.
This tells us not much.
Did you read and follow the instructions in the Release Note?
If so, where did it fail?
