bbbbbobber
Nov 17, 2018Aspirant
firmware version discrepancies
I'm logged on to the router, preparing to set up a VPN soon, and went to Advanced and the only version I can find is for Cable Information. It shows a version of V1.01.26. I'm hoping to get the route...
- Nov 18, 2018
bbbbbobber wrote:
so the R6220 that I have is both a modem and a router.In that case, it is not a R6220.
R = Router
C = Cable modem/router
D = DSL modem/router
You have a C6220
There is support for this device at the end of this link:
>>>C6220 | Product | Support | NETGEAR<<<
You can ignore the firmware on this device. It is beyond your control.
The 1.1.0.80 is for the R6220.
michaelkenward
Nov 18, 2018Guru - Experienced User
bbbbbobber wrote:
How can I set this up so that new versions upgrade automatically, if possible?
Not all routers support that.
I would point you at the support pages for your device, but I can see n o sign of the R6220v2. It may be a new version of the older R6220:
>>> R6220 | Product | Support | NETGEAR <<<
That shows the latest firmware as Firmware Version 1.1.0.80, but that probably will not work on the R6220v2. Firmware does not transfer between firmware variants.
I have no idea where the V1.01.26, it is the wrong format for Netgear firmware. But what is this "cable information"?
bbbbbobber
Nov 18, 2018Aspirant
Thanks for your help - it appears that I'm looking in the wrong place.
'Cable Information' is one of the four boxes that appear after I have logged in at routerlogin.com with 'admin' and my router's password.. Then I change from the 'Basic' tab to the 'Advanced' tab and a window of four boxes shows. They are identified left-to-right and top-to-bottom as
Cable Information Internet Port
Wireless Settings (2.4GHZ) Wireless Settings (5GHZ).
Within the Cable Information box, it shows:
Hardware Version 1.04
Firmware Version V1.01.26
Cable Modem Serial
Number
etc.
