eldiener
Oct 27, 2019Tutor
Firmware version inconsistency
Running the Netgear Genie web application when I check for a later firmware version with Advanced | Administration | Router Update I am told that I have the latest firmware. The firmware that is show...
- Oct 27, 2019
> [...] The firmware that is showing in the web aplication for my router
> is "V1.0.3.6_1.0.63CH". [...]That"CH" means that you have special ISP-specific (Charter/Spectrum)
firmware, not the general Netgear firmware.> [...] Can anybody clear up why [...]
You don't have an ordinary R6300v2; yours is special. There have
been some discussions of how to load ordinary firmware onto a device
which currently runs ISP-specific firmware ("CH" or "SH"), with mixed
results. See, for example:https://community.netgear.com/t5/x/x/m-p/1543374
A Web or forum search for your current firmware version should find
others.
antinode
Oct 27, 2019Guru
others.
eldiener
Oct 28, 2019Tutor
I am a Charter subscriber. I did not realize that Charter has their own model separate from the normal Netgear models. I have no need to upgrade the firmware if I do indeed have the latest Charter firmware version.
