Aguajera
Aug 13, 2021Follower
FIRMWARE VERSION UPDATES
I have never downloaded any of the firmware updates for my Ex6200 AC1200 bought in 2017. Must they be installed in sequence or will the latest cover all previous versions? Thanks in Advance
- Aug 13, 2021
You can just install the latest. you don't have to install them in sequence.
Aug 13, 2021Guru - Experienced User
- michaelkenwardAug 14, 2021Guru - Experienced User
That usually works, but there are times when the updates are just too dramatic. Too much changes.
Try it first, and if that fails and if it doesn't work try something in the middle.
Where possible take this route:
How do I manually upgrade firmware to my NETGEAR router? | Answer | NETGEAR Support
