Aguajera's avatar
Aguajera
Follower
Aug 13, 2021
FIRMWARE VERSION UPDATES
I have never downloaded any of the firmware updates for my Ex6200 AC1200 bought in 2017. Must they be  installed in sequence or will the latest cover all previous versions? Thanks in Advance
  • plemans's avatar
    Aug 13, 2021
    You can just install the latest. you don't have to install them in sequence.
