JGL991
Aug 14, 2021Guide
Firmware Version V1.0.4.118_10.0.90 FIRMWARE ISSUE FOR ROUTER AC1750 SMART WIFI R6400V
A week ago i logged onto router and updated the firmware with what was suggested by Netgear. Ever since then, I keep having issues with DNS. Every site I select from the list of search results come...
- Aug 14, 2021
here's where you can get the firmware: R6400v2 | WiFi Router | NETGEAR Support
for older firmware, click on "view previous versions"
then just follow the manual firmware update process but use the older version you downloaded and not the newer.
Aug 14, 2021Guru - Experienced User
I'd downgrade to the version prior. Seems to resolve it for issues.
I've seen multiple posts on here about recent upgrades breaking dns so I have a feeling netgear is aware of it.
- JGL991Aug 14, 2021Guide
How do I do that? I do not know the version prior?
- plemansAug 14, 2021Guru - Experienced User
Thank you I did not see the previous link before
