JGL991
Aug 14, 2021Guide
Firmware Version V1.0.4.118_10.0.90 FIRMWARE ISSUE FOR ROUTER AC1750 SMART WIFI R6400V
A week ago i logged onto router and updated the firmware with what was suggested by Netgear. Ever since then, I keep having issues with DNS. Every site I select from the list of search results come...
- Aug 14, 2021
here's where you can get the firmware: R6400v2 | WiFi Router | NETGEAR Support
for older firmware, click on "view previous versions"
then just follow the manual firmware update process but use the older version you downloaded and not the newer.
JGL991
Aug 14, 2021Guide
Thank you I did not see the previous link before
keneddy
Aug 27, 2021Aspirant
Went to the current version of firmware. My issue wasn't as pervasive as what others had reported. I would get a message "HMMM - Page couldn't be loaded" (Perhaps this was the DNS issue reported by others) then 4/5 seconds later it would load. Occaisionally, there would be problems with the rendered page. After doing a lot of searches and trying some setting adjustment the problem was still present. Installed chrome and tested and the problem disappeared. Fell back to edge and the problem would popup. I have a router on either side of a hardware firewall. The issue never surface on RTR1 only RTR2 behind the firewall. No error messages in the FW log. I reversed RTR2 and RTR1 and the problem stayed with RTR2 now infront of the firewall. REalizing that although I had WIndows maint recently I alos upgrade rtr2's firmware. So risking bricking the router I opted to fallback to the prior version and move the routers back to their original location. I retested for about 30 minutes going against a URL that regularly had the issues. Couldn't recreate the issue.
Probably wasted about 3 or 4 hours over 2 days diagnosing and resolving...
- JGL991Aug 28, 2021Guide
I went back to the previous version and have had no problems anymore. i do not allow windows to download updates to my laptop or do maintenance to it. It is the only way i have been able to keep my laptop for 10 years now
