mrbones's avatar
mrbones
firmwarer wont update
Hey folks got a question from a non literate computer person. So i got an email from netgear saying my router needs a firmware update for security reason. So i followed the link to their page and cli...
  • antinode's avatar
    antinode
    Dec 04, 2017
    > When i downloaded the file from netgear i would double click and every
    > time it said the file was corrupt and would not open.
       Did "the file from netgear" have a name?  Was it a ".zip" archive?
       Zip archives have important data near the end of the archive.  If the
    file gets truncated during a file transfer, then you can get some kind
    of corrupt-archive error message because those important data are
    missing.  The size of WNDR4500v3-V1.0.0.48.zip (as I fetched it) is
    14286683 bytes, and the file I got was undamaged:
    pro3$ unzip -t WNDR4500v3-V1.0.0.48.zip
    Archive:  WNDR4500v3-V1.0.0.48.zip
        testing: WNDR4500v3-V1.0.0.48.img   OK
        testing: WNDR4500v3-V1.0.0.48_Release_Notes.html   OK
    No errors detected in compressed data of WNDR4500v3-V1.0.0.48.zip.
