atlantic
Jan 09, 2017Aspirant
firmwear upgrade for 582384
I started the process for the upgrade and walked away from my computer. I am not sure if the upgrade happened. Where can I check this and what version would be indicated? Thank you.
- Jan 11, 2017
There are links to the firmware updates for the affected routers here: http://kb.netgear.com/000036386/CVE-2016-582384
What router model do you have?
michaelkenward
Jan 10, 2017Guru - Experienced User
What is a 582384?
atlantic
Jan 11, 2017Aspirant
| Security Vulnerability: VU#582384 |
The Vulnerability: NETGEAR is aware of the security issue #582384 that puts a network at risk by allowing for unauthenticated web pages to pass the command-line interface leaving open the potential for arbitrary command execution by remote attack. |
- StephenBJan 11, 2017Guru - Experienced User
- atlanticJan 11, 2017Aspirant
Thank you for the link. I still have my original question. My model number is R7300.
- michaelkenwardJan 12, 2017Guru - Experienced User
It is hard to know what the original question was.
Let me rephrase it. Are you asking:
Is there a firmware update for the R7300?
If that is your question, then the answer is:
- Follow the link that StephenB posted (see above or go here Security Advisory for CVE-2016-6277, PSV-2016-0245)
- Read the page you land on
- Look at the list of devices for which there is new firmware
You can also look at the manual for your device and read the bit about firmware upgrades.
The manual is here:
R7300DST | Product | Support | NETGEAR
See page 178.
You will see that the router will tell you if there is an upgrade.
