manxdoc
Nov 11, 2020Guide
Flash RBR50 to RBS50
Hi I have a RBK50 system, one RBR50 router and one RBS50 satellite. I have another RBR50 router which I cannot use but I could use another RBS50 satellite. Can I flash the RBR50 to use as a RBS50?...
- Nov 11, 2020
I've never done it so I can't tell you if it can/can't be reversed.
I do know you definitely stand a chance of bricking the device.
manxdoc
Nov 11, 2020Guide
Thank you plemans, very helpful!
I read somewhere that the process can't be reversed. Is that right or can I go back and reinstall the router firmware?
Am I taking the risk of "bricking" the router?
Thanks
Thanks
