MarkDover
Oct 13, 2021Follower
Flashing issue R6220
Hello Community - I have some issues with router R6220 I have flashed it to operWRT and then I've tried to do the same to ddWRT with .img file but it failed. It hang during the flashing proc...
Oct 13, 2021Guru - Experienced User
You need to contact openwrt or ddwrt forums for help with their firmware.
Its 3rd party firmware and they're the experts on it.
- plemansOct 13, 2021Guru - Experienced Usersadly its the risk you take when flashing 3rd party firmware. You might brick your device and the forums on there warn you have that.
- cookdanielOct 14, 2021Aspirant
plemans wrote:You need to contact openwrt or ddwrt forums for help with their firmware.
I agree with this.Move your firmware file to the same directory as nmrpflash.exe
Open a command prompt with administrator privileges.
Switch to the directory where nmrpflash.exe and your firmware file are located. For example, if they are in a folder called flash on your Desktop, run the following command: cd C:\Users\YOUR USERNAME\Desktop\flash
Turn off the router, and connect it your computer using a network cable.
In the command prompt, run nmrpflash -L.
You'll get a list of network interfaces, named netX. Identify your Ethernet connection, for example net3.
Run nmrpflash -i net3 -f "YOUR FIRMWARE FILE NAME"
Turn on the router, and flashing should commence.
