GwentLarry
Aug 01, 2021Aspirant
Frequent & repeated of IP address to new network device
Hi,
Model D6220
Modem Router Firmware: V1.0.0.74_1.0.74
MacOS 11.5.1
I've recently added a new wifi device to my home network, a solar PV inverter. This is all working fine and I can see the solar panel data via the manufacturers web site.
Except, my Netgear router is resending the same LAN IP address to the inverter around 4 or 5 times an hour, pretty much continuously.
The only thing I can think is that the wifi signal is weak at the inverter and the connection keeps getting lost and then reconnecting …?
Any other thoughts?
I guess I should get a wifi extender/booster?
D6220 (your message) or D6200v2 (your footer)?
A bit more detail might help. You never know, someone may have turned up here with questions about the same device.
I don't understand what that means.
You might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware.
DSL Modems & Routers- GwentLarryAspirant
michaelkenward wrote:D6220 (your message) or D6200v2 (your footer)?
GwentLarry wrote:I've recently added a new wifi device to my home network, a solar PV inverter.
GwentLarry wrote:Except, my Netgear router is resending the same LAN IP address to the inverter around 4 or 5 times an hour, pretty much continuously.
DSL Modems & RoutersThe label on the router is D6220 - the Model dropdown doesn't list that …
The device is a SolarEdge SE5000H Inverter for a Solar PV system - that connects to the manufacturers servers, uploading data on performance which I can monitor.
The router log lists [DHCP IP: (10.175.0.3)] to MAC address 28:B7:7C:14:86:18 four or five times an hour. That MAC address is the SolarEdge inverter. This doesn't happen with other devices on my home network.And I find the options for where to ask questions rather less than obvious … :-)
GwentLarry wrote:
The router log lists [DHCP IP: (10.175.0.3)] to MAC address 28:B7:7C:14:86:18 four or five times an hour. That MAC address is the SolarEdge inverter. This doesn't happen with other devices on my home network.So it is more a case of the router logging an incoming connection request than "resending the same LAN IP address to the inverter".
So your theory about the wifi begins to make sense. Or it could be that the inverter tries connecting to a schedule.
The router is just logging what goes on.
That 10.175.0.3 IP address is a bit puzzling. It isn't one of usual 192.168.x.x defaults, and usually happens when there is something else on the network handing out IP addresses.
There's a long discussion about SolarEdge inverters here:
Solved: Constantly dropping connectivity - NETGEAR Communities
That's why I asked what it is.
I have no idea if it adds anything useful to your search for information. But it may suggest some things to try.
You are being too kind to the system, which is also responsible for the gaps in the drop-down options.
