OliverWhite
Jan 14, 2019Aspirant
Frequent power cycling required to recover wireless network
During this past week, my WNDR3700v4 with firmware version V1.0.2.102 requires power cycling once or twice a day to recover my wireless network. The wireless network becomes unavailable, and cannot b...
- Jan 14, 2019
You won't lose dual band nor speed settings. Just it will be different firmware.If you run into any issues just let me know and I'll assist you.
wcalifas
Jan 14, 2019Prodigy
If you're fed up with it before you replace it you should try the third party firmware called dd-wrt on it since that router is on the list where you can use dd-wrt firmware on it. Might solve your wifi issue. Just my 10 cents.
- OliverWhiteJan 14, 2019Aspirant
I may try installing different firmware. Will I lose many features of my router? Dual band? Security? Speed setting?
- wcalifasJan 14, 2019Prodigy
