jkonz
May 28, 2020Aspirant
FS108 DC Power Supply
Hello, I am looking for more information about what is the acceptable DC input power range for the FS108. The datasheet only says 7.5V at 1amp. But there must be an allowable range, can someone p...
- May 29, 2020
> Would like to know if either 5V or 9V would work instead of 7.5V.
I'd need to look at the design of the regulator of the FS108 to
decide that question. My guess would be that higher would be more
likely to work than lower, but whether the design would tolerate that in
the long term is another question (to which I lack the answer).A quick+dirty(+cheap) scheme might be to put a couple of Si diodes in
series with the 9V supply to drop/waste about 1.4V. Not classy, but
probably good enough. And a little better than a direct connection to
9V.
michaelkenward
May 29, 2020Guru - Experienced User
The ProSAFE range is pretty esoteric kit compared with the General WiFi Routers (Non-Nighthawk) devices covered in this bit of the forum. I doubt if ProSAFE experts hang out here.
You might get better and quicker replies, and find other answers, over in the appropriate section. That's probably here:
Switches - NETGEAR Communities
or here
Smart / Plus / Click Switches - NETGEAR Communities
There might even be a Netgear specialist following that area.
