Markinla
Oct 05, 2022Follower
Full speed not reached by wifi connection on Nighthawk R6400v2 with firmware version V1.0.4.128_10.0
My cable company recently up my speeds from 130Mb/s to 350 Mb/s. I have a wired connection to the Nighthawk and that achieves the correct speed using the Ookla speed test app on my Mac. That connecti...
michaelkenward
Oct 06, 2022Guru - Experienced User
You don't say what wifi speeds you get with the R6400v2 but if this is a wifi speed test, maybe that s as fast as the wifi clients can handle.
Is it a lot faster when you try it on other wifi sources?
It might be worth a bit of background reading.
Understand Wi-Fi 4/5/6 (802.11 n/ac/ad/ax)
@duckware knows their stuff and can bust a few myths and cut through marketing hype.
