louisadele's avatar
louisadele
Initiate
Jan 31, 2022
Full URLs
Hi, Hope you all are doing great. How can I get full URLs from history? Thank you.
  • FURRYe38's avatar
    Jan 31, 2022
    You gave us nothing to go off. What NG product are you referring too?
    To get a hold of support. Click on "MyNetgear" at the top.
    Register an account (or login) and then the device.
    From there you can start the support process. Keep in mind that its only free for the first 90 days.
    There's a support site with access to manuals, firmware, install guides, etc.
    Go to https://www.netgear.com/support/
    Type in your model number and from there it'll take you to the above.
    Its a great resource to start with.
