TexasIndian's avatar
Dec 08, 2020
general router LAN port use
(question pertains to both this current router + future AX router)
Again, PLEASE feel free to speak 'techno-inept'..no idea what LAN even means!
Both current router (which I plan to 'pass-on' to daughter's family) & AX waiting on
have several LAN ports...my MS-employed + obviously MUCH more techno-savvy
neighbor asked me "why aren't you 'plugging devices' into your router"?  To which
I so eloquently replied "huh"?.  He said the wifi printer sitting on shelf 6' away is an
ideal candidate.  And since we're now raising (and subsequently 'hybid schooling')
3 grandkids, I should 'plug-in' their Chromebooks into LAN ports too; even if they
are only 'plugged-in' while in my office for a couple hours doing homework.   ???
  • > [...] ..no idea what LAN even means!
       Try a Web search?
          https://en.wikipedia.org/wiki/Local_area_network
       A device which has an Ethernet interface can usually be connected to
    a LAN Ethernet port on a router, instead of using a (LAN) wireless
    connection.  You typically gain speed and reliability, but lose
    portability.
       A Web search for terms like, say, "home network" might have some
    educational value, too.
       Try a Web search?
    portability.
    • TexasIndian's avatar
      TexasIndian
      Tutor
      well hell, seems too simple (or me too stupid) once you actually SEE
      "Local Area Network" visually spelled out
