jsolo53
Jan 16, 2018Guide
Genie Advanced settings don't display
My first post here. I've been running two R6250 in my home network, one as Wifi router and one as an access point. It all ran fine for a year or so - until my cable modem died. Replaced the modem ...
- Jan 16, 2018
Problem Solved - just needed to turn off ad blocking software.
michaelkenward
Jan 17, 2018Guru - Experienced User
Well done, thanks for the report back. It might help fellow victims in future.
Out of interest, which browser and blocker?
jsolo53
Jan 17, 2018Guide
Adblock Plus
Now that Netgear Genie on the main R6250 (the one used as router) can see the second R6250 (the intended AP), I would like to set the intended AP to work as a stand alone wireless access point. Problem now is connecting to the intended AP. routerlogin.com only gets to the main R6250. Using Chrome and entering the intended's IP fails to connect - times out every try. The connection between R6250s is wired ethernet plugged into one of the LAN ports on the main R6250 and into the WAN port on the intended R6250. Got any ideas? How can I reach netgear genie on the intended AP?
- antinodeJan 17, 2018Guru
> see the second R6250 (the intended AP), [...]
This "Netgear Genie" is the web-browser interface? (Ever helpful,
Netgear uses the name "Genie" for more than one thing. Netgear routers
have a web-browser interface called "Genie", and Netgear offers
application programs for various computers/pads/phones, which are also
called "Genie".)
"see" how, exactly? Is "the second R6250 (the intended AP)" already
configured as an AP, or is it still (or back) in full-function router
mode?
> access point.
What's a "stand alone wireless access point"? "stand alone"?
That's to be expected. How could one name point to your choice of
two different devices? To access the WAP, you'd need to specify its LAN
IP address. If it's still in full-function router mode, then you'd need
to be connected to its LAN, not the main router LAN. (Or else enable
remote management access, and use its WAN address, I suppose.)
> out every try.
Which "the intended's IP"? If it's still in full-function router
mode, then it has a WAN IP address and a LAN IP address. Each interface
(LAN and WAN) has its own address. And you normally need to be on its
LAN side to reach its web site.
> R6250.
That's reasonable if the second one is already in WAP mode. If it's
still in full-function router mode, then the best thing to do may be to
connect a computer to its LAN, and switch it to WAP mode.
It would help in understanding what's happening if you revealed the
actual IP addresses of this stuff.
My usual advice is to shrink the DHCP pool range on the main router
to, say, ".2" - ".199", and configure the WAP LAN address to ".200" or
".250" -- something memorable, and outside the (main router) DHCP pool.- jsolo53Jan 18, 2018Guide
Thanks for your reply. The info has helped!
Now when I key routerlogin.com I (still) reach the R6250 router. If I key the IP 192.168.1.222, I reach the R6250 Access Point, which I have now set to be an access point and given it an IP (192.168.1.222). Back on the R6250 router, I have shrunk the DHCP pool range to 2-199, as you suggested.
But I don't think things are where they're supposed to be, because my wireless devices (laptop, ipad, iphones) see the two R6250s as separate pieces; the main router as ssid Netgear87, and the access point as ssid Netgear86. Before the cable modem died, the wireless devices only saw Netgear87 (2.4, and 5).
What else is there? Should I use the same ssid and password on both R6250s?
- antinodeJan 18, 2018Guru
> [...] The info has helped!
What could go wrong?
> [...] Should I use the same ssid and password on both R6250s?
Sure, if that's what you want. Using different SSIDs lets you decide
where (and on which radio band) your client device will connect. Using
the same SSID (and passphrase) everywhere lets your client device
decide.
Everything depends on the local environment, but if the two access
points (router and WAP) can sense each other, then they're likely to
choose different radio channels automatically. (Or, you could configure
the radios manually to use different channels. But watch out for
neighbors.) This would let you detect which access point you're using
by getting the client to disclose which channel it's using.
On the bright side, you could choose a more interesting SSID (and a
more memorable passphrase) than the Netgear default one(s).
