jb83
Sep 23, 2018Aspirant
genie app
so I was using the genie app to turn off certain devices that was on my network. the app would freeze. then when I tried it a second time I lost all internet connection to my whole network. now my rou...
- Sep 24, 2018
jb83 wrote:
and I can access it through direct plug in with the ethernet cable. and that works fineWhat does that mean?
Access what? Ethernet cable from what to what?
Do you mean that wired devices can connect to the internet through the router via the LAN ports?
jb83 wrote:
.. .I turn on the wifi my ssid pops up but cannot connect to the internetWhat does that mean? What "cannot connect to the internet"? And what happens when you try?
Remember, when you factory reset the router you wiped out any settings that you might have made, to the wifi password for example.
michaelkenward
Sep 24, 2018Guru - Experienced User
It sounds like you have been thrashing around blindly a bit. What do the LEDs on the R7000 show? Especially the Internet LED.
It may help to reboot the whole network in the right order.
- Turn off and unplug the modem.
- Turn off the modem router and computers.
- Plug in the modem and turn it on. Wait 2 minutes.
- Turn on the modem router and wait 2 minutes.
- Turn on the computers.
- jb83Sep 24, 2018AspirantI've tried that to no avail. my internet light is not lit at all but everything else is white.
- michaelkenwardSep 24, 2018Guru - Experienced User
There is support material, including a manual, for the R7000 somewhere at the end of this link:
>>>> R7000 | Product | Support | NETGEAR <<<<
Check the bit Troubleshoot with the LEDs.
What modem sits in front of this thing?
In general, we know not much about your system and how you are accessing the router. The more you can tell people the better.
- jb83Sep 24, 2018AspirantI have a ubee modem from my ISP. that I bridged to use my own netgear router. i used the genie app from the android play store to shut off a device or pause the internet to it and it shut off the whole network and hasnt work since. I'm not to tech savvy. so im not exactly sure what the hell im doing
- jb83Sep 24, 2018Aspirantsorry the light is amber.. and I can plug my ethernet cable in my laptop and get internet but when I plug the ethernet back into the router. theres no internet connection
