geoffstreeter
Aug 20, 2016Aspirant
genie will not accept WPA-PSK [TKIP] + WPA2-PSK [AES]
Firmware Version V1.0.0.52_1.0.81 Can set the radio button but when I press "apply" I can see the button change back to WPA2-PSK [AES]. This is giving my Motog+ problems. This has Android v6. E...
- Aug 30, 2016
Yes that worked. I have been at the Greenbelt Festival all weekend - sorry. I tried it today after I got back.
I restored it from scratch - everything entered by hand.The thing I did not restore was that I was serving up a reserved IP from the router to the phone. I can't actually see that making a difference.
One thing I noticed was that the router went out on the web to register me. However the screen that comes up to do that placed the REGISTER button off screen at the bottom. I did it again but with a reduced "minimum font size" from 16 to 12 - ancient eyes. That did not get the whole thing on screen but it did get the button on screen.
At least it layed the blame on the router rather than the phone.
Thank you for the support.
geoffstreeter
The article "Cannot set WPA2-PSK(AES) security" seemed to answer most of this. In order to change the setting you have to go via the "None" option, apply it and then choose the option you want and apply that.
Didn't solve the issue of connecting my MotoG+ though.
- AnonymousAug 21, 2016
The setting you want requires you to lower the mode to 54. Since you omitted most of the useful information one could only guess.
- geoffstreeterAug 21, 2016Aspirant
Sorry, this was about the UI provided by Genie to get at firmware settings. What is mode 54? How am I supposed to set it? The UI is not the place to do that.
What I am really trying to do is to get my MotoG to connect - it does elsewhere. Whilst trying to explore that issue I noticed this odd effect and thought it might be part of the problem.
Of course if there is a more sophisticated access to the firmware that will give me some debugging assistance then I would love some pointers to that.
What details did I omit? I gave model, firmware reference and a description of what I was seeing? What else would you like that Genie can provide?
Router model?
2.4 or 5g?
mode is a speed setting ....up to 54...up to 300...up to
What channel?
