junyan2000's avatar
Mar 04, 2021
Gigabit speed on GS305
I understand GS305 has to be plugged directly into a router in order to get gigabit speed. Does that mean with two GS305 connected to each other, there is no way to get gigabit (because only one GS30...
  • antinode's avatar
    antinode
    Mar 05, 2021
    > I did get my facts straight before posting.
       Please feel free to pass along any useful information.  For example,
    what's an "AC6700-AC"?  Or:
    >    Are there speed-indicating LEDs on any of these gizmos, or software
    > which you can interrogate?
    > [...] after I swapped the switches, speed goes up to 30 MB/s.
       Perhaps, but a bad device or cable could explain such problems, too.
    > Do I have to connect the router only on port 5 of GS305? Port 5 was
    > explicitly mentioned in guide for GS305P [...]
       If you have a GS305, then why look at the installation guide for a
    GS305P"?  If you're confused by this, then how confident should I be
    in your "I did get my facts straight" claim?
       Visit http://netgear.com/support , put in your (actual) model number,
    and look for Documentation.  Get some (for your actual model).  Read.
       With a simple unmanaged switch (not one with PoE), the ports are all
    equivalent.
