Fuggal
Dec 07, 2019Aspirant
Google Chromcast won't connect to WNDR4300 router
I'm having trouble connecting my Chromecast in a long-term vacation rental that has the WNDR4300 router. My iphone and computer connect just fine to the house's WiFi network. The Chromcast recognizes...
- Dec 09, 2019
This might help eg. for the WNDR4300: Chromecast will not connect to wifi
From the above link:
===Here are the detailed steps to find that box:I have a Netgear WNDR4300 router that was blocking my new chromecast from connecting via the wifi password. I was typing it in correctly but it kept giving me the error "Connection problem during setup! - Chromecast could not connect to Netgear - Please check your password". I spent hours trying to resolve it only to realized it came down to one option in my router settings.
- Go to your router settings by typing your ip in to a browser
- Click on advanced in the upper left corner
- Click on 'Setup' -> QoS Setup
- Check the box next to "Enable WMM (Wi-Fi multimedia) settings for which ever frequency your wifi is connecting to (2.4 or 5ghz)
- Click 'Apply'
- Reset your chromecast and start the app up again and that's it!
schumaku
Dec 09, 2019Guru - Experienced User
- Click 'Apply'
Fuggal
Dec 09, 2019Aspirant
Oh my, it worked!!! Thank you so much.
Enabling that WiFi multimedia setting was the issue (it makes perfect sense now once you've pointed it out).
Like you, I spent many hour on this (several days, actually).
You saved me!!!
