Whitecro's avatar
Aug 10, 2021
GS105E linked connection limited to 100M
Hi  I have GS105E with 5 ports. Four of the ports are working at 1000 although the one connected downstairs to my router is only connected to 100M. I've checked with the manufacturer of the router a...
  • Whitecro's avatar
    Whitecro
    Aug 11, 2021
    Your a legend. It was the cable, my cable tester showed 1-8 good with the exception of no.7 not lighting up indicating a problem. Pulled it out of the wall and it was slighly nicked and hanging loose. I would have thought it would've killed the connection but no, it reduced it like you said to 100. Flying on 1000Mbps now although for some reason I cant see the switch IP address on my router. Maybe takes time to propagate.
    Thanks!
