lali0020
Jun 08, 2021Follower
GS105v4 Connection drops
I have a my home network connected from the cable modem to eero 6 router and then out to an 8 port TL-SG108 gigabit switch. That switch feeds 5 rooms. One of the rooms needed another switch and the gs...
michaelkenward
Jun 09, 2021Guru - Experienced User
You have posted your message in the section of this community given over to General WiFi Routers (Non-Nighthawk). (This is easily done, given Netgear's complicated community structure.)
Many questions apply to different types of device, so there may be useful responses here, but the GS105|5 Port Gigabit Ethernet Switch is very different from a basic router, so you might get more help, and find earlier questions and answers specific to your device, in the appropriate section for your hardware. That's probably here:
Switches - NETGEAR Communities
or
Smart / Plus / Click Switches - NETGEAR Communities
In the meantime you could visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
You may have done this already. I can't tell from your message.
I mention it because Netgear stopped supplying printed manuals and CD versions some years ago and people sometimes miss the downloads.
