Alex1973785's avatar
Alex1973785
Follower
Apr 21, 2021
GS110EMX POE
Hi all,
Can anyone let me know if this switch model support POE for security cameras ?
Thank you very much
Alex
1 Reply
  • schumaku's avatar
    schumaku
    No. Netgear PoE switches carry a "P" (or two) in the product designation.
    Head to the Netgear Switch selection https://www.netgear.com/business/wired/switches/ to select the level of manageent, then use the "show all" - on the subpage you get a filter for PoE capabilities (versions, power, ...) to compare.
