Tieka's avatar
Tieka
Follower
May 03, 2021
GS305 Unmanaged switch app
Hi! Could anyone tell me what app I need to connect my switch to the internet with? I'm a bit confused as I have used all of the apps and none of them worked.
1 Reply
  • > Hi! Could anyone tell me what app I need to connect my switch to the
    > internet with?
       I doubt it.  A GS305v2 is an unmanaged network switch.  You don't
    need any app to do anything with it; there's very little which you could
    do with it, with or without an app.  You simply connect Ethernet cables
    to it and watch the pretty LED indicators.
    > [...] I'm a bit confused [...]
       I agree.
    > [...] as I have used all of the apps and none of them worked.
       "all of" _which_ "the apps"?
       "Didn't work" is not a useful problem description.  It does not say
    what you did.  It does not say what happened when you did it.  As usual,
    showing actual actions (commands) with their actual results (error
    messages, LED indicators, ...) can be more helpful than vague
    descriptions or interpretations.
       What, exactly, are you trying to do?  Have you some kind of Internet
    service?  A modem?  A router?  Why did you get a GS305v2?  Is there some
    actual problem which you are trying to solve?
       General advice: You might have more success if you described
    (clearly) the actual problem which you are trying to solve, rather than
    asking how to implement some particular "solution" ("what app") which
    may have little or nothing to do with the actual problem (whatever it
    might be).
