Craig-Brown's avatar
May 02, 2021
GS305v3 Ports
I understand that I need to connect the input from my modem/router to one port, and all outputs to other devices to the other ports. Which port (1-5) should I use for the input from my modem/router? ...
  • Craig-Brown's avatar
    Craig-Brown
    May 10, 2021
    >  Because there's nothing to say?
    For someone like me, who is ignorant of switches, etc., it would have been nice if the manual (such as it is) actually said that it doesn't matter which ports are connected to what device. Saying nothing is not the same as having nothing to say. Just because you are an IT geek doesn't mean everyone else is.
