Craig-Brown
May 02, 2021Tutor
GS305v3 Ports
I understand that I need to connect the input from my modem/router to one port, and all outputs to other devices to the other ports. Which port (1-5) should I use for the input from my modem/router? ...
- May 10, 2021
> Because there's nothing to say?
For someone like me, who is ignorant of switches, etc., it would have been nice if the manual (such as it is) actually said that it doesn't matter which ports are connected to what device. Saying nothing is not the same as having nothing to say. Just because you are an IT geek doesn't mean everyone else is.
Craig-Brown
May 03, 2021Tutor
I suspected it doesn't matter, but the documentation is very sparse, and doesn't say anything about the ports.
antinode
May 03, 2021Guru
> [...] the documentation is very sparse, and doesn't say anything about
> the ports.
> [...] When you read the product documentation for your network switch,
> did you find any suggestion that any of its ports behaved differently
> from the others?
So, that'd be a "No", then?
Another possibility would be to run the experiment.
- Craig-BrownMay 10, 2021Tutor
- antinodeMay 10, 2021Guru
> [...] Saying nothing is not the same as having nothing to say. [...]
True, but having nothing to say is a good reason to say nothing.
Still true.
> [...] it would have been nice if the manual (such as it is) actually
> said [...]Perhaps, especially for a consumer market, but there does come a
point where more detail is a senseless waste. Netgear product
documentation could certainly use improvement, but I don't recall ever
seeing a car owner manual explaining which way to turn the steering
wheel to make a right turn. Or which way "Reverse" pointed.
