Spaztic
Mar 20, 2021Aspirant
Gs608 ethernet switch crashes internet
When plugging in and turning on the Ethernet switch it stops my router and internet services working, what could be the issue
antinode
Mar 22, 2021Guru
> When plugging in and turning on the Ethernet switch [...]
What, exactly, is connected to what, exactly? (Hint: If a device has
different types of Ethernet ports, then "connected to device" is not
enough detail.)
Are you connecting only a switch port to a LAN port on the router, or
are other devices connected to the switch, or what? Is the switch
causing the problem, or is some device which is connected to the switch
causing the problem, or what?
