taherte
Apr 09, 2024Tutor
Guest network ac1750 model R6300v2
I don't really know what I am doing but I set up a guest network yesterday. I tested it today and found that when I connected to the guest netowrk, I was able to view files and folders on my PC's har...
- Apr 09, 2024
Problem solved. There actually was no problem except between my ears. Sorry for wasting everyone's time. Thanks for the quick replies.
Apr 09, 2024Guru - Experienced User
What firmware version are you on?
taherte
Apr 09, 2024Tutor
- plemansApr 09, 2024Guru - Experienced User
You could try updating the firmware. Not sure if it'll help but you can always try.
https://www.netgear.com/support/product/r6300v2#download
that router is pretty out of data. You might check into some 3rd party firmwards like dd-wrt or tomato for it.
They'll give it a few enhancements over stock.
Just be advised, there's always a chance of bricking a device when installing 3rd party firmware.
- schumakuApr 09, 2024Guru - Experienced User
Start with the installation of R6300v2 Firmware Version 1.0.4.52 and check this Guest WLAN again following the mandatory reboot.
- taherteApr 09, 2024Tutor
