carterbrandon's avatar
Sep 14, 2019
Guest network isolation with WAC104 access point
This is a question about the 'guest network' feature on my DGND3700v1 router (with richud firmware and Genie interface) when there is also a WAC04 access point on the network. The router supports 'Gu...
  • antinode's avatar
    Sep 14, 2019
    > [...] looking at the setup screens in the WAC104 user guide online, it
    > seems to have no concept of 'guest network' as such. [...]
       I know nothing about the WAC104, but I'd expect that.
       The guest-network implementation on Netgear routers seems to be a set
    of firewall-like (router) rules which affect the "guest" wireless
    clients.  A wireless access point which is separate from the router has
    no way of employing any such router-based rules.
    > [...] if a visitor connects as guest at the WAC104 (rather than at the
    > DGND3700) [...]
       The whole guest-network concept is confined to the DGND3700 (router);
    there is no "as guest at the WAC104".
    > [...] would they therefore have a route to my PCs, or would they
    > encounter the blocks imposed by the guest network settings on the
    > DGND3700?
       When any device is connected to the WAC104, the DGND3700 will see it
    as a wired client device (hence not a "guest"); just another device on
    the (extended) LAN.
       There may be ways to employ multiple (consumer-grade) routers to
    provide a "guest" LAN subnet and a non-guest LAN subnet, with the
    desired type of isolation between them.  Or, a more sophisicated router
    with Virtual-LAN (VLAN) capability (about which I know nothing) could
    probably do the job.  But I don't see a way for a DGND3700 and a WAP to
    do it.
