ThomasfromFL
Mar 22, 2022Aspirant
Half Speed issues with AC1000
Just activated my Spectrum account in FL, connecting wired directly to cable modem gives purchased 200+Mbps speeds. When I connect the router and connect my laptop speeds are cut in half, both wired...
Mar 22, 2022Guru - Experienced User
Pretty sure all the AC1000 routers aren't gigabit routers.
they've only got 10/100mbps ports on them.
so the fastest speed you'll get is going to be that 94mbps (ish).
But like FURRYe38 says, what actual model is it?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with. And its data sheet and manual will go over what ports and speeds the model supports.
ThomasfromFL
Mar 23, 2022Aspirant
Its the R6080, I selected it from the list, it stated everyone in the community could see it??
- michaelkenwardMar 23, 2022Guru - Experienced User
It wasn't visible on your first message.
Thanks for adding it.
