ThomasfromFL
Mar 22, 2022Aspirant
Half Speed issues with AC1000
Just activated my Spectrum account in FL, connecting wired directly to cable modem gives purchased 200+Mbps speeds. When I connect the router and connect my laptop speeds are cut in half, both wired...
Mar 22, 2022Guru - Experienced User
Pretty sure all the AC1000 routers aren't gigabit routers.
they've only got 10/100mbps ports on them.
so the fastest speed you'll get is going to be that 94mbps (ish).
But like FURRYe38 says, what actual model is it?
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with. And its data sheet and manual will go over what ports and speeds the model supports.
ThomasfromFL
Mar 23, 2022Aspirant
Manual states "download speeds up to 1000Mbps
- michaelkenwardMar 23, 2022Guru - Experienced User
That's wifi.
But the data sheet says:
WiFi speeds up to 300+700Mbps†
Even then it is economical with the reality.
It also refers to local wifi speeds. Between two devices connected to each other over wifi.
It will never get that on an Internet connection. As plemans explained, the wired bit can't manage anywhere near that
† Maximum wireless signal rate derived from IEEE 802.11 specifications. Actual data throughput and wireless coverage will vary and may be lowered by network and environmental conditions, including network traffic volume and building construction. NETGEAR makes no representations or warranties about this product's compatibility with future standards.
