6400v2notgood
Oct 04, 2022Follower
Have to reset R6400v2 daily
Like the subject says it drops daily. Last netgear anything I buy. Thanks!
michaelkenward
Oct 06, 2022Guru - Experienced User
That's is not "like the subject says": "drops daily" is not the same thing as "reset daily".
Have you done anything to troubleshoot your problems and to check that it isn't something else on your network that is the issue?
