green89043
Apr 05, 2022Aspirant
Having issues with R6080 internet/wifi connection. Wired connection still works
My AC1000 Dual Band WiFi Router, model R6080 is acting funky. All lights on the router are green except for the internet signal. When I try to connect to my 2.4G WiFi network, my phone will to try to...
- Apr 10, 2022
green89043 wrote:
My router is still showing an amber/ orange light meaning it has a 100Mbps link, right?
Depending on which light we are talking about – there is a row of them on the router – amber certainly signifies 100 Mbps on LAN connections.
But being an basic router, the R6080 doesn't have the same diagnostic indicators as other routers.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.The manual will explain what the LEDs mean.
green89043
Apr 10, 2022Aspirant
Devices were originally suggesting the 5GHz wifi network. I had them forget the regular 2.4GHz network and was able to connect my devices and smart bulbs to the 2.4GHz network. I believe having my devices forget the 2.4GHz network did the trick and resolved the issue. Internet speed test on my computer and phone are showing a strong connection to the 2.4GHz network (+30Mbps download/ +5.70Mbps upload).
michaelkenward
Apr 10, 2022Guru - Experienced User
Support | NETGEAR
- green89043Apr 11, 2022Aspirant
Thank you! I appreciate the help figuring out what was wrong with the wifi!
