jsmitten
Aug 18, 2022Aspirant
Help- slow wired speeds on R6400v2
Help! I just upgraded my internet speed to 900 mbps, bought a new Netgear CM1000 modem and R6400v2 AC1750 router to accommodate the higher speeds but am only getting around 200-350 mbps on my Xbox S...
michaelkenward
Aug 19, 2022Guru - Experienced User
jsmitten wrote:
I've spent hours on the phone with comcast and netgear trying to figure out what is wrong.
As well as talking to Comcast and Netgear, wouldn't Microsoft also be worth quizzing?
Did your research include this?
Search - NETGEAR Communities – Xbox
The Xbox seems to be the devil's plaything. As you can see, you are not the first one to hit problems.
- plemansAug 19, 2022Guru - Experienced User
Seems that if everything else other than the xbox is hitting those speeds, its the common factor in the slow down.
- jsmittenAug 21, 2022Aspirant
You can't get any chat or phone support from xbox in regards to slow connectivity anymore. Their support page just links you to articles with solutions I've already tried. I got them to respond on twitter, followed their steps and they didn't fix the issue. It could be my router settings, it could be their servers, it could be Comcast restricting my bandwidth. I'm not getting dropped, my connection is solid, I'm just paying for a speed I specifically signed up for to improve my gaming experience and not getting the benefit.
First thing I tried. Xbox Live provides no support for connection issues. They used to, but not anymore.
All those people have different issues than me, but thanks for the snark. The devil does not exist.
