jsmitten
Aug 18, 2022Aspirant
Help- slow wired speeds on R6400v2
Help! I just upgraded my internet speed to 900 mbps, bought a new Netgear CM1000 modem and R6400v2 AC1750 router to accommodate the higher speeds but am only getting around 200-350 mbps on my Xbox S...
michaelkenward
Aug 19, 2022Guru - Experienced User
jsmitten wrote:
I've spent hours on the phone with comcast and netgear trying to figure out what is wrong.
As well as talking to Comcast and Netgear, wouldn't Microsoft also be worth quizzing?
Did your research include this?
Search - NETGEAR Communities – Xbox
The Xbox seems to be the devil's plaything. As you can see, you are not the first one to hit problems.
Seems that if everything else other than the xbox is hitting those speeds, its the common factor in the slow down.
