scooby102
May 08, 2023Aspirant
help...
I haven’t used my Netgear AC1600 for 1.5 years and I want to use it as a wireless access point. I am not able to change the settings (I can login) but it just says server IP address could not be foun...
michaelkenward
May 08, 2023Guru - Experienced User
How do I change my NETGEAR router to AP mode? | Answer | NETGEAR Support
Then there is the manual.
AC1600 is not a reliable guide to model number. Many devices come with an AC tag, but it is essentially a label that Netgear, and other brands, attach to hardware to describe wifi speeds.
Look on the router for the label that says "Model Number"
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual Use the Router as a Wireless Access Point or something along the same lines. (The exact wording may depend on which AC1600 you own.)
I called Netgear and they wanna charge me $150 to update the security and will be working again. WTF.
Your router may date back to 2105. Rare is the brand that offers free lifetime support for what is essentially an inexpensive consumer product. Even Netgear offers support at far less then $150.
How about $49.99
This place is free.
