Moetmoet
Feb 20, 2020Aspirant
Help me open router port to access remote view on my ip security camera
Hello, I need help finishing setting up my Home security camera, so that I can use the camera remotely and not just while my device is on same wifi as camera. My camera is wired directly to my router,...
- Feb 20, 2020
Hi Moetmoet, welcome to the community! Page 84 of the user manual linked below may help out.
http://www.downloads.netgear.com/files/GDC/C3700/C3700_All_MSOs_UM_EN.pdf
Dexter
Moetmoet
My house was broken into last night and I need to set this up tonight before I have to leave for work tomorrow with no access to my camera. Anything helps, thank you
DexterJB
Feb 20, 2020NETGEAR Moderator
Dexter
- MoetmoetFeb 21, 2020AspirantThank you for your help. Simply turned off extra IPv4 firewall protection and it worked just fine
