artworksmetal
Nov 04, 2016Tutor
Help me understand thie odd DHCP behavior
My network has about 15 devices on it (network A), half of them wired. I added an Ubiquiti AP out in my yard set to WDS repeater mode. I bridged to another old router in a building 300 feet away to...
- Nov 10, 2016
OK, so it was explained to me that when a device accesses the network, it takes the first DHCP offered to it. In this case the AP on Network B was reaching back through the bridge to assign IPs before the R6400 could respond. I didn't know it could do that.Silly me, I thought it would only assign them on Network B, where it was set up as the AP.
The solution was to turn off DHCP on network B, and let the R6400 assign the IPs on both networks. I didn't know it could work that way, either!
artworksmetal
Nov 04, 2016Tutor
The plot thickens, as I open the DHCP client list on router B (AP) . It shows these devices with IP addresses above 100 as being on its client list. Mostly android devices, but even my Roku which is which has an address reservation of 5, and is wired to the main router.
So maybe my real confusion is that Access Point does not mean what I think it means.
