mic9
Nov 26, 2019Aspirant
Help: Netgear WNDR3700v2 firmware
Im having trouble with my router... Its wifi is working but no internet.. My findings, it was loaded with an world wide firmware.. Can anyone help me pin out when can i get a North American firmwar...
- Nov 29, 2019Dont mind this..
I already found the solution..
The routers 2.4G is damage.. Why? If you connect higher device like laptop with/without password.. This signal goes haywire and sometimes will not emit signal.. But on small devices like phones working fine..
5G signal is ok..
antinode
Nov 26, 2019Guru
> [...] My findings, it was loaded with an world wide firmware..
Interesting, but how you reached that conclusion might be more
interesting.
> Can anyone help me pin out when can i get a North American firmware
> for this router..
Visit http://netgear.com/support , put in your model number, and look
for Downloads. (For older versions, under Firmware and Software
Downloads, look for "View Previous Versions".) Find the kit(s).
Download the kit(s) you want. Read the "Release Notes" file for
instructions.
> V1.0.0.12 or higher ..
"V1.0.1.14" seems to be current, "V1.0.1.12" available. I see
nothing about different firmware for different regions.
mic9
My router is NA version.. I upgrade its firmware with world wide version..
I upgrade it, because im having a problem of sudden disconnection of wifi and sometime no internet even if it has..
Im from V1.0.1.14 NA before i upload the V1.0.1.12 WW
Im not expert on this, i just update the firmware to fix the problem.. But its not doing good, the problem gets worst. Now the wifi is not giving internet..
I already go to downloads section and look on previous version.. Theres no North American version
- mic9Nov 29, 2019AspirantDont mind this..
5G signal is ok..
