mic9
Nov 26, 2019Aspirant
Help: Netgear WNDR3700v2 firmware
Im having trouble with my router... Its wifi is working but no internet.. My findings, it was loaded with an world wide firmware.. Can anyone help me pin out when can i get a North American firmwar...
- Nov 29, 2019Dont mind this..
I already found the solution..
The routers 2.4G is damage.. Why? If you connect higher device like laptop with/without password.. This signal goes haywire and sometimes will not emit signal.. But on small devices like phones working fine..
5G signal is ok..
mic9
My router is NA version.. I upgrade its firmware with world wide version..
I upgrade it, because im having a problem of sudden disconnection of wifi and sometime no internet even if it has..
Im from V1.0.1.14 NA before i upload the V1.0.1.12 WW
Im not expert on this, i just update the firmware to fix the problem.. But its not doing good, the problem gets worst. Now the wifi is not giving internet..
I already go to downloads section and look on previous version.. Theres no North American version
mic9
Nov 29, 2019Aspirant
Dont mind this..
5G signal is ok..
5G signal is ok..
